How old is my Panda
Engine, increases, electronic parts, bodyworks, tyres, plastic etc ....
How old is my Panda
Messaggioda ploughboy » martedì 28 luglio 2020, 16:50
Hi
I've just bought a Panda 4 X 4 but don't know the year. Can I find the year from anything on the car. The reg is AL-050-CW.
ploughboy
Re: How old is my Panda
Messaggioda Flero » martedì 28 luglio 2020, 17:21
ploughboy ha scritto:Hi
Can you put a photo of the exterior door and one of the interior (dashboard, steering wheel and seats) ?
Pay attention that the images do not exceed 2 MByte
You can see also this link:
https://en.wikipedia.org/wiki/Fiat_Panda
Messaggioda ploughboy » mercoledì 29 luglio 2020, 17:34
Here,s the drivers door
ploughboy
Messaggioda ploughboy » mercoledì 29 luglio 2020, 17:57
Here’s the dash and interior. Sorry the last picture was the passenger door
ploughboy
Messaggioda Birrone » mercoledì 29 luglio 2020, 18:07
ploughboy ha scritto:The reg is AL-050-CW
Assuming AL-050-CW is the original Italian plate number, this Panda has been registered in Rome district in the last week of december 1996.
Of course this information is unuseful if the vehicle has been re-registered form another district (very frequent in Italy in those years) or coming from abroad.
In order to know the year model and the building data from the registering data, we should have the VIN (chassis number) instead of the plate number.
Hi,
Messaggioda ploughboy » giovedì 30 luglio 2020, 17:07
Hi Mauro
Thanks for the information. The VIN is ZFA141A0001209743. Can you date it more accurately now?
ploughboy
Messaggioda ploughboy » giovedì 30 luglio 2020, 17:56
Theres also a problem with the car not starting. It was driven to a dry garage about 6 months ago, so ok then. When I came yesterday the battery was flat. I replaced it with a new one but no start. I checked a spark plug and no spark, and don't think any petrol is getting to the carburettor. Then I noticed the warning lights on the dash - see picture. Could this be the reason?
I don’t know what the “code” refers to. That isn’t in the handbook for the car, it should be a seatbelt warning light. I’m not aware of an immobiliser on the car but the previous owner might have installed one I suppose? The one below says it means a problem with the injector- related to the “code”?
Has anyone any ideas?? I’m stuck!!
ploughboy
Messaggioda Birrone » giovedì 30 luglio 2020, 19:07
ploughboy ha scritto:Hi Mauro
From https://www.vindecoder.pl/ZFA141A0001209743
Codice: Seleziona tutto
Make   Fiat
Model   Panda
Model year   1995
Trim level   Base
Body style   3 Doors Hatch
Engine type   1.1L L4 SOHC 8V 4WD
Fuel type   Gasoline
Vehicle class   Subcompact Car
Vehicle type   Passenger car
Manufactured in   Italy
Body type   Hatch
Number of doors   3
Number of seats   5
Displacement SI   1108
Displacement CID   68
Displacement Nominal   1.1
Engine type   L4
Engine head   SOHC
Engine valves   8
Engine cylinders   4
Engine aspiration   Naturally
Engine HorsePower   50
Engine KiloWatts   37
Fuel type   Gasoline
Driveline   4WD
Hi,
Messaggioda Birrone » giovedì 30 luglio 2020, 19:13
ploughboy ha scritto:I don’t know what the “code” refers to
There is the drawing of a key... it might mean that the engine key you are using is not programmed with the correct code (or a "passive" key without the transponder).
In case I'm right, you could solve it only in an official Fiat service.
Hi,
Messaggioda ploughboy » giovedì 30 luglio 2020, 19:23
Thanks a lot for the information about the car. The only thing about the key is that it did start the car 6 months ago. Could the battery replacement have affected the key operation?
ploughboy
Messaggioda ploughboy » giovedì 30 luglio 2020, 19:45
Hi again
I’ve taken pictures of the key. I’ve noticed a symbol on it and a number on the other side. Does this mean it is a transponder key that might have a code error?
ploughboy
Messaggioda ploughboy » giovedì 30 luglio 2020, 19:51
Also forgot to say I put 20ml of petrol directly into the carburettor and tried again to start it. As before it turned over but did not start
ploughboy
Messaggioda Flero » martedì 25 agosto 2020, 17:02
You have a "Magneti Marelli" single point electronic injection version
When the engine just does not start, the first thing to check is whether the inertia switch has engaged (it engages automatically in the event of a collision or road accident and blocks the fuel pump).
In this case, however, when you turn the key in the ignition, you do not hear the noise of the petrol pump at all.
However, when the "Key Code" light stays on, the problem is different.
It could be the faulty key or the "Key Code" transponder which must read the key code.
I guess you've tried, if you have one, to start it with another key.
Keys with transponders can be duplicated ... as long as they are not broken.
I would first try to go to a key duplicator shop, if they can read the KeyCode of yours most likely the problem is with the transponder.
If they can't read the KeyCode and you only have one key ... there's a problem!
Another test you can do is try to borrow a compatible control unit of a Panda that does not have the keycode or has the keycode scodified from a Fiat garage.
For example, I have this:
it is not perfectly programmed for our engine (176B2000) but it works and above all it does not have the keycode. In an emergency ... you always manage to get home.
Torna a Tech Area
